snoob
Everything posted by snoob
  1. can you replace the ignition module or do you have to replace the distributor? I had a major electrical short and the battery blew up on the freeway there was a small fire under the dash it was the remote door lock controller an aftermarket one from autozone that was on fire and burnt some other wires and blew up the battery i think i fixed all the shorts and removed the remote lock BS but the distributor seems to have no spark i tested it like it says in the haynes book and the book says if its bad to replace the distributor but i found the vg33 IGNITION MODULE that's inside the distributor and seems to be the part i really need autozone and checkers don't carry this part but i found it on ebay for $60 but i found the distributor for $115 VG33-Distributor i just need to be shure i fix it so maybe the whole distributor is the way to go its only money.
  2. i got all teh parts and iam going to take some pics and do it as soon as i get a day off work
  3. hey I found this while searching for wiring diagrams for my key-less entry maybe it will be useful here on this great forum pathy manuels
  4. thats good advice i mostly wheel in the desert around central utah but theres a lot of rough rocky tera and alot on fine dusty sandy dirt i also like the snow. i was looking at BFG A/T tires ,goodyear and BIG-O but i want 32 inch or 31.5 in a narrow tire because i want to tuck the tires
  5. I am thinking about the 32X9.50R15 size theirs only a couple brands that make the size, Simex is one and there to expensive to get in the U.S. is there and more brands, i really want 32x9.50 but i guess 265/75R16 will do.
  6. hey iam not sure its OK to post stuff from other forums but i found this while i was looking for the how to on wheel bearings maybe it will help a little how-to-replace-brake-rotors-and-pads-for-2001-qx4-pathfinde (sh*! i just noticed its for a 2001)
  7. I picked up all the parts to do front wheel bearings but as I read the how to it seems i should change the seals, That makes sense becuze bad seals could be the reson there so worn,I was just wondering if anyone has done this job and how long should it take me and is there any thing else that needs replaced while I have the wheels apart ,I know I need manual hubs Still, I did get break pads.
  8. hello iam in slc
    nice to meet ya
  9. wanting more
