bradbritt
Everything posted by bradbritt
  1. Posted this in General as well, Hello everyone great forum, first post. I am going to have the power valve screws tightened/Loctite at the dealer (quote 2.8 hrs) What is the specific Loctie that should be used? What other preventive service should I have done at this time? The Pathfinder is a 2002 with 35,000 miles. I was thinking I should have the plugs changed and the throttle body cleaned since everything is apart and the cost is less to have the service done at that time. I have head about issues with the valve cover and would think that this would be the time to replace it. Is the PVC valve replaceable on its own or is it a one piece assembly with the valve cover? Should I have them clean the MAF at this time? Any thing else that I missing? Thanks again for a great forum!
  2. I am but just don't have the time, Im wondering more than anything what I should have done at the same time since things will be apart and it will cost less to do at that time.
  3. Hello everyone great forum, first post. I am going to have the power valve screws tightened/Loctite at the dealer (quote 2.8 hrs) What is the specific Loctie that should be used? What other preventive service should I have done at this time? The Pathfinder is a 2002 with 35,000 miles. I was thinking I should have the plugs changed and the throttle body cleaned since everything is apart and the cost is less to have the service done at that time. I have head about issues with the valve cover and would think that this would be the time to replace it. Is the PVC valve replaceable on its own or is it a one piece assembly with the valve cover? Should I have them clean the MAF at this time? Any thing else that I missing? Thanks again for a great forum!
  4. I put these on in November http://www.yokohamatire.com/tires/geolandar_hts.aspx Great tire, got them from the dealer for 125.00 each and the 4th tire was free. $435.00 for 4 tires installed and balanced at a nissan dealership. Make sure you get a 4wd alignment. These tires are highly rated on tire rack. Good luck.
