kts96
Everything posted by kts96
  1. How do you calibrate the shifter cable?
  2. tranny/shifter goes into gear just fine. eveything is hooked up I double checked. even check the wires on the gear selector to make sure
  3. Hi, I got a 93 4x4 Pathy with and auto trans. I just changed out the trans from a 94 Pathy because the old one quit working. Got everything hooked up and when you put it into gear there is no movement at all in any of the gears. anyone got any clues. Thanks
  4. My Pathy is bogging when I stomp the gas to the point that it wants to die out. I have checked for codes and found none. I have changed the following to no avail. Distributor, Wires, Plugs, Fuel Filter, Fuel Pump. Any ideas?
