sportsman2171
Everything posted by sportsman2171
  1. AH! Thank you lol was having trouble tring to pull the carpet up from the back hatch side i guess I was starting from the wrong side? Thank you I will try that tomorrow and I tried going up to auto zone and getting my codes checked but they said they didnt have the right systems for the obd1 systems. Any other suggestions on where to get that done?
  2. I have no problem with that idea im just trying to figure out how to locate the fuel pump
  3. Wow you know your stuff huh? Didnt really think of the ecu yet have only worked with the obdII system and didnt know how really the obdI worked I will go up to auto zone and do that tonight and when I tried to access the fuel pump to check for chugging or spitting. But when I went to pull up the rear cargo area the carpet felt like it was adhesived down so I stopped... Is this the correct way to access it? I will try and get the trouble codes and post tonigh thank you all for all the help!
  4. So how did you get the blockage out? Its hard to even diagnose the problem saying as it only happens intermittently? Any suggestions?
  5. It pretty much dies instantly... If it were electrical why would it have to sit for a little before starting back up? I am very confused with this and im starting to get aggravated. I will still have to check that fuel pump thing out today when I get home i will let you all know thanks
  6. Wow whats the luck! Thanks so much for the response. I'll check into that as well whilst im checking the fuel pump. I used to have all data at my old auto tech school but no longer go there... Does anyone know the procedure for doing this? Thanks.
  7. Thanks for the feedback! I have filled up a couple of times and just last fill up put injector cleaner into it so I wouldnt think it was the gas...And if it was the pick up then why is it only when making u turns or sharp left turns? So a steering syatem flush worked for you? Why would that cause me engine to stall and not start back up some of the times? And i thought about the fuel pump issue to and thank you for the advice on that... I'll try that tomorrow afternoon and see how that works out. Not trying to say anyone is wrong here just making sure im finding the right culprit in this situation its juat very confusing and odd to me! Ha
  8. Recently bought a 91 Pathfinder from a friend. He said it would sometimes stall out. We replaced the fuel filter and he said it worked normally for about 2 weeks then went back to stalling intermittently. He said he put fuel injector cleaner into it and it didnt stall for about 2 months but then pnce again atarted stalling. I took the truck off his hands and am now trying to fix it! I have npticed that this only happens when I am slowing down and making a sharp left turn. has happened about 5 times in the week ive had it. Sometimes it will start right back up other times i have to let it sit for about 15-30 minutes. Anybody know what this could be? Any suggestions would be great! Also sort of surges when accelerating after a stop like a possible fuel issue im just not that knowledgeable of fuel related problems. Thank you.
