Everything posted by jonyb
Glad I found this thread, I'm looking into a set of headers as well. So Nissan Motorsports or Thorley's? Anyone have anything used? Also, what about an exhaust? Something on my truck has a leak and it's either the exhaust manifolds or the exhaust pipe, so I'm just gonna replace it all.
What part of KY did your's go to? Southern Indiana? What town? I'm about 2 hours south of Evansville.
Back to the drawing board.... Someone locally supposedly had a trans for this truck for $250. At least that would get me around in it until I could have the other one rebuilt. Finally got in touch with that person, and it's for an Isuzu Trooper
Thanks for the link.... I'll read up on this stuff before I make some phone calls on Monday. I'm positive it's not a body lift. I knew it was suspension but I haven't looked to see exactly what the lift consisted of. I'm hoping they didn't just crank the TB's.... Kinda anxious to get this thing on the street. My daily driver is an 04 Caddy CTS-V and it doesn't even like the rain. Snow and ice is on the way for KY and I'm sure the Vettillac won't do so hot on all of that.
I found the link before I started the intro thread. It's the Transgo kit, but I wasn't sure if I could have the trans shop use that and not need any more parts. I think I've found another trans locally for $200, so I may just buy that one, have it installed, then have them tear into mine to see what they think. Thanks for the advice on the trans cooler, I hadn't heard that one yet. Could I just bypass it right now to see if that works? If that's the case, I'm sure an upgrade would be in order. Thanks for the welcome fellas! Found some pics...
Nissan didn't start the transponder until 2000. If your's does have one, the bypass is simple. There's 2 ways to do it. 1. www.idatalink.com; they make interface modules for remote start to OEM. The ID piece wires in, then it's programmed by the installer. Once the programming is complete, the module simulates the key being in the ignition, but only while the remote start is in the remote start sequence (normally about 10 seconds). This goes for around $50-$75 2. A key box; Peripheral and DEI made a keybox that had a wire that wraps around the ignition cylinder. You had to physically put a working key in the box, then hide it under the dash (I always wrapped them in electrical tape and stuffed them way up under the instrument cluster). During the remote start sequence, the box with wire going to the cylinder, would simulate the key being there. These are around $25-$35. Pricey, a little, but if you've ever had a remote start and had big changes in weather, you'll spend a few extra dollars. Im in Western KY so it's humid as can be in the summer, and in the 20's right now. When I get off work and my car is cold from sitting in the parking lot for the last 13 hours, I'll have it running 6 minutes before I get in to leave. It's nice waving and driving by everyone as they scrape their windows off. You don't have to do that if you set the defrost before you get out...
Hi all, just found this place and lurked for a while. Looks pretty informative as most all forums are. I'm in the Western KY area and work at an industrial facility full-time on a 14 day/month swing shift, and also am part owner of a small car audio/security and marine audio dealer in my town. I do mostly all the installs for our customers. I just picked up a 95 Pathy V6 4x4 auto from a friend. It's been around my area for about 5 years that I know of and has been taken care of for the most part. Has a 3" lift (not sure how it's lifted just yet), 33" BFG's, black steel wheels, matching spare on the tailgate, and a roofrack that's just dying for 2 sets of Hella's. The Pathfinder has seen better days though. I bought it with a burned up transmission. The big problem is that there's no reverse. 1st gear seems to lag a little like it slips as well. I think I have a used trans spotted locally for $200, but that's not a for sure deal yet. The local transmission shop said somewhere in the ballpark of $1,800 to remove, rebuild, and reinstall the current one that's in there. I'll be using the search function for most of this, but since I have this thread, I wanted to ask a couple questions... *The trans shop said the planetary gear is the main problem. Is this true? *If I have it rebuilt, what's a reasonable price? *I've read in the other threads about the Transgo shift kit. I'm assuming that the Planetery gear that's burned up will still need to be replaced, but will the TG kit give me most of the parts for rebuild? I know nothing about transmissions and I'm leaving it to the pro's around my area to do the work. Thanks for any help!!! I'll post up some pics once I get back out in the shop.
