tlrmax
    05 pathfinder le 2wd
    Do Not Go Off-Road
tlrmax's Achievements
  1. so did you get the new pathy? New interior looks way better.
  2. You can check by looking at your drivers door jamb to see if their is a sticker that says "radio prewired for satellite". If you do have then you can use the oem satellite. I installed it on mine but I did have the 6disc bose. If it does have it then the factory plug is above the drivers kick panel. Its a white plug just taped up to another harness. Then ground and run antenna. You dont have to take radio out! Cheapest place to buy sirius or xm unit is at grubbs performance parts. $200 plus antenna.
