clark
Everything posted by clark
  1. its in the right fender right beside the battery
  2. you can just take the thing apart and resolder the broken jonts in side and it will work again it is very common for the solder joints to crack on these
  3. Its in the right fender beside the battery. theres to two plugs going in to it .let me guess olny one light come on with the day time runing lights?
  4. thats what i wanted to hear thanks for your help
  5. it broke right at the pumpkin on the left side, the brakes are still good but the shaft the wheel bolts to is broken at the spline, I am wondering if its as easy as pulling the shaft out and removeing the drum backing plate and installing the disk brackets and lines and puting the same shaft back in?
  6. I did a 180 when i hit some black ice at 100kph and slid backwards into one of them cement road block things it tore the tube right off the on the left side and the frame was so rusted out that it tore the rear half of the frame from the sway bar mounts back. off it sucked
  7. Hello everyone, can a drum brake rearend be swaped to disk? and how hard is it to do? I ask because my finder has a lsd drum rearend and ive got a parts truck that has a open diff disk brake rear end but has a broken axel tube making swaping the whole rear end not an option.Thanks
