pathydaddy
    i gots a 95 Pathy all stock with 31in swampers
    Screwdriver Mechanic
    Choose
    Choose
pathydaddy's Achievements
  1. lol for a 2wd hardbody and B if i had the money to throw around id buy them.,..but i dont so i thought id ask lol!!!!
  2. just curious will the UCAs for a 2wd work? as i can snag a set of 3in UCS for a 2wd hard body for 50 bucks brand new and there superlift ones... tel me quick so i dont loose out on them!!!!!
  3. Precise you answered it perfectly... i runnin 31s with flairs with no torsion adjustment right now.. i would think even doin a 3in BL would be enough for 33s but then again maybe not (oh yea flares are off and there flawless and for sale lol)
  4. so i now have the money to do the 3in ucs and jgc coil lift and was gonna order some rough country UCS due to the fact there on 55 bucks a piece.. but everyhting i have read on here says it will give 3 in of lift in the front with the ucs but on RC website they advertise it to only be 1.5-2 in.. can someone enlighted me on here as i want to run 33s so i was plannin on doin a 3in BL too but its not worht it if im only gonna get 1.5-2 off the ucs... also other than shocks the ucs and jgc coils is all im gonna need on the suspension end right?
  5. haha sorry yall was tryin to post a vid but apparently i only got the screen shot... sorry for the hype lol
  6. so i can use the older model kit and just buy 2 bolts for the rear? did i understand that correctly? it would just be bolts that are (preferably grade 8) same diameter thread pattern just 3 inches or so longer right?
  7. so all the body lifts i can find say there for 86-90... nothin that lists my 95 so is ther one out there for my 95 and if so where or will the 86-90 setup work? also none specify if it will work with an auto trans.. Im sorry i know this has been covered but i seem to be reading yes and no's so im looking for one last final answer as i got the money and wanna do it befoer the wife says no!!!
  8. go to the link.... its my pathy.. i had to upload it to you tube.....
  9. i was thinking about your idea this morning about the gas can i have only owned it for 2 months so i dont know the history really of the vehical i did a full tune up when i bought it and the o2 sensor is with in values and the maf is very clean... im jus thinkin something between the tank and cluster is off any more ideas?
  10. im guessing maybe a bad tourqe convertor
  11. ok so we went through did a new fuel filter put in a thermostat (old one froze open) and checked exhaust for being plugged... so heres a mini story with pics lets see what yall have to say numbers and figures here dont add up! ok so i pull into the gas station to fill up tonight.. here is where my fuel gauge sat as i shut the rig off as you can see its almost empty right? like real damn close now after the fill up this is what the pump says. so 13.9 gallons to fill it up thats after topping it off so much it was spitting gas out what makes me so confused is that my pathy is a 95 so it has a 21 gallon tank in it yet if my math is right 13.9 gallons should only be like 3/4s or so of a tank. or am i loosing its not in the pic but the odo shows 178 miles on a full fill up. i have stock 31 10-5 15 tires on it and the rig is bone stock and 110xxx miles on it and brand new trans can someone give some advise as to what is going on here fuel gauge off? (tach doesnt work) so cluster shot or the fuel sender float or what this is really upsetting me casue if i infact have a 21 gallon tank this means im gettin like10 mpg and thats not gonna cut it for me i drive 45 miles a day for work and i cant keep affording this any help would be great
  12. im averaging about 10 miles a gallon... barely getting 200 miles to a full tank (21 gallon tank too) theres no ecu codes bein thrown 180k on the odo plugs wires and all that look good... im just goin after the cheap fixes first like thermostat then fuel filter then guy cats make sure there not plugged... we dont have DEQ here!!!!!! any other pointers?
  13. as i thought and was told by my mechanic buddy. now with that said saying that is the issue beings the water and engine not up to temp would that indicate that the ecm is getting the wrong signal via temp sensor causing it to run rich? thus engine mileage going to s***???
