Hello
I own a 2001 st pathfinder with bfg at's, There only 29inch stock size tyres.
The delema i have is on the last trip i made into the Victorian high country (Australia, melbourne) i think i got a bit to confident with my stock setup and
found myself going down hills that made me want to change my underpants, at one stage i'm sure i had one rear wheel off the ground about 1/2 a foot, anywayz ok ok.
the 4x4 handled it well but because the front being so engine heavy i found i was bottoming out and i was collecting planetarium size rocks as i crawled down the hill.
I have thought about what i want to get out of my ride and at the start i was going to lift it as much as possible but now i think i would like a nice camping/tourer
that will still handle some heavy exploring.
I recently emailed 4x4parts.com about importing the 2 inch Deluxe AC lift kit you guys in America seem to like, warn manual hubs, 2 degree camber kit, because here in aus theres no full off the shelf 2 inch lift kit.
The delivery cost to Melbourne AUS was going to be an extra $450 AUS dollars ontop of the aprox $1600 for the 2 inch kit and extra gear.
I dont think i will go down that path for now.
So if, FOR NOW <---- Before my easter trip i wanted to get toughdog 35mm lifted springs wich i can get locally and try to use the stock black nissan pea shooter shocks for my trip, being a higher spring rate and lifting the 4x4 at least 1 inch or 35mm i hoped it would help a little with the sharp bottoming out, do you think this combo is do-able and ok to use for now because i aint rolling in it atm, once i get back i will match the spings with a full 45mm big bore strut and shock set. Also would i need the camber pin set?, will the stock adjusters pull the camber in or out enough? with only 35mm lift.
Thanks heaps for your help, if it cant be done i will settle for lesser tracks for a bit
I will try to post some pics of latest trips if i have some and if me being a noob can get it to work
I think this mud was developed by the Australian government to stop anyone with AT's thinking there top sh#t.
I crossed this river without a snorkel, it hit just above the lights for a split second, there was a little dip on the way through.
