All,
When I bought my 98 XE, I found out the previous owner had all the 8 rear arm bushings replaced . I also just recently replaced my front struts/rear shocks, strut mount bearings, ball joints, repacked the front bearings and adjusted my toe settings using a large "toe-plate" to essentially 1/16" toe (as best as I could). The tie-rod ends are in good shape as are the swaybar links, i.e. tight/no clicking/no rattling. I have the stock lower strut bolts, so no camber can be adjusted (other than a small wiggle). Couldn't see any caster adjustment either and none that I've read about.
So even after all the suspension components have been replaced, my Pathy still pulls to the right. I've learned that pull usually stemmed from a misaligned rear, i.e. thrust angle pointing right or left, thus the pull. Excessive toe caused instability and wear, not pull.
So my question is: can the rear arms be adjusted? Not so much on thrust angle since it's a solid axle, but in a "yaw" setting? I couldn't find any posts about rear alignment adjustments.
Thanks again for all your help. My Pathy is so close to driving the way I'd like it to!
- Al
