I will go ahead and change out the cooler, not a problem. I was just curious as to why I only have the problem with the reverse gear and all the others work fine. If the fluid is causing problems would it not effect the functionality of all gear ranges?
In any case when I do change out the cooler and the problem is still present, do I need to consider the reverse clutch? If this is indeed the case will this require the removeal of the tranny and will I have to completely rebuild the unit or just tend to the reverse clutch?
Man this is getting deep, whatever happened to the quick fix?
Anyway, I really appreciate your help in this matter. This is the first time that I have had to deal with this type of issue, usually I just remove the tranny and send it down to the local shop and they benchwork it. I am told the Nissan trannys tend to get expensive if you take it to a shop.
Thanks,
