PwninOBrien
Silver SE
Skilled/Experienced Mechanic
Rarely Go Off-Road
2002
2,774 profile views
PwninOBrien's Achievements
Stalling every startup and low idle.
PwninOBrien replied to pathlesstaken's topic in 96-2004 R50 Pathfinders
Depending on how long the battery was disconnected, you may need to do the idle air volume learning procedure. If you're still having the problem then I would troubleshoot or replace the MAF. Also, the 2003 models have the IAT (intake air temperature) sensor built into the MAF sensor. EDIT: I'm an idiot, I just read that you did the relearning procedures. I would start by troubleshooting the MAF. -
I'm a tard, I just realized that you said rack and not cargo basket. The second fairing in my pictures is 5" tall, so you may want to just measure from the top of the load bar to the roof just to be sure. You also don't want the fairing to be flat (where the distance from the top of the load bar and the roof is 5" exactly) since it will pretty much negate any benefit of a fairing. I think their fitment guide is extremely generic and it doesn't work well when it comes to accessories.
You want this fairing.. not this one... right? You can get the first one through Yakima directly, it's considered a replacement part and not an accessory.
Those are some serious lights you have there, 500W and 550W lol Where did you get them? A baseball field? haha
Electric Cooling Fan Conversion
PwninOBrien replied to laxman0324's topic in 96-2004 R50 Pathfinders
I should also point out that one benefit that the mechanical fan has over an electric fan is the shroud. The shroud allows the mechanical fan to spread out it's CFM's evenly over the entire radiator. The ideal setup would be to have two fans with a custom shroud, although it's not very economical. As long as you can cover most of the vertical channels in the radiator then you should be fine. I recommend getting the largest possible fans; I think the last time I checked the R50 has 27 5/8" of finned area, which is just small enough to prevent the use of 14" fans, unless you figure out some way to mount them to the radiator safely. -
Well you really have to look at it this way, when the stock fan is at 100% duty cycle is when there is very little air flow through the radiator fins (idling/city driving). During these low RPM's scenarios the fan spins at a fairly slow speed, thus pulling very little CFM's. I would not recommend an electric fan conversion if the vehicle is used for hauling since that requires high RPM's at slow speeds. This could also be seen as a negative when off-roading, since normally you use the lower gears (with higher RPM's) at slow speeds. The key is to use a fan with the highest possible CFM's with the most radiator coverage. Now the 12" perma-cool fans are rated on Jegs and Summit at 3,300CFM at 2,400RPM's; two of these on the radiator would pull a total of 6,600CFM at any point. This means that even at idle, you would be pulling more CFM's than the stock fan at the higher duty cycles. Most dual fan controllers have a relay for A/C hookup. Both fans should turn on at the pre-determined temperature, however when you have the A/C on then one fan should always be on. Like shift220 said, most likely if you're running the A/C then both fans will be on from the increase in coolant temperature. One thing that should also be noted is that you need to make sure your electrical system can handle an extra 20+ amps; if you have a lot of electrical accessories running at the same time as the fans then the last thing you want to experience a brown-out is your cooling system. -
I have a couple of extensive write-ups on this on NICO. Here's a short version of the write-up... Go with two fans, a custom shroud setup will be too expensive and won't be much more beneficial than a two-fan setup (versus a single fan setup). The largest fan size for a dual-fan setup on the R50 radiator is two 12" fans. Your best bet is to go with something like two Perma-cool high performance electric fans, as said above, it won't be cheap. After getting two fans and a dual controller you're looking at about $250. The perma-cool fans will cool much better than the stock fan and should and will provide more than adequate cooling. You can use two single controllers or a single dual controller, it really depends on what you want to use. The temperature measurement location really depends on which controller you buy, there are kinds that you stick in the fins and there is the kind that goes into the drain plug or on other radiator orifices. Obviously the kind that uses a probe that you stick in the fins is less efficient but they are much more common. Your best best is to wire one fan to turn on automatically when the A/C is on and then both turn on at a specific temperature. You can purchase variable speed fans and controllers (Flex-a-lite sells some) but you would be looking at shelling out some serious money (around $500) so I would suggest sticking with some standard ON/OFF fans. I haven't done the conversion yet but that is the next mod on the list. If I complete the conversion I will definitely take some detailed pics and some instructions. It it super easy to complete the conversion and should take no more than a single afternoon. -
2003 R50 Performance Exhaust Options
I highly recommend Magnaflow over Flowmaster. Flowmasters are more for sound than performance whereas the Magnaflows are flow-through and not baffled like the Flowmasters. As far as backpressure is concerned, you want to use pipe as close to the factory diameter as possible. Most exhaust shops would recommend going no more than 1/2" larger; any larger and you start to lose EGV's and you will start losing low-end torque. -
You would be hard-pressed to find any shop with a mandrel bender, they are far too expensive. You can always buy pre-bent pipe and take it to the shop and they can cut it up and make it work. Unless you buy a pre-made system then you're probably stuck with a crush-bent system. I suggest Magnaflow mufflers, they have a great warranty and are made of stainless steel. If you get stainless pipe then the exhaust system will outlast the car (except for the hangers). -
K&N makes an intake kit specifically for the R50 Pathfinder.Link: K&N Pathfinder FIPK
Since you installed the intake is your idle now higher than 750 RPM's? If that's the case then the DTC is for the high idle and you need to reset the ECU and do the re-learning procedures. On your 2003 there isn't a screw method, but rather a pedal method where you reset the ECU via a series of accelerator pedal presses. I also have the K&N intake on my 2003 Pathfinder, I ran into the same problem with the two vacuum inlets on the K&N intake tube. I spoke to the engineering staff at K&N and it turns out that the extra vacuum inlet is not necessary for the 2003 and 2004 Pathfinder. It is simply a vacuum line that was removed after the 2002 models. I would just recommend putting a bypass cap over the extra inlet.
3.5L V6 Nissan Power Adds - Best Practices?
PwninOBrien replied to Oregonian's topic in 96-2004 R50 Pathfinders
I definitely wouldn't recommend removing the intake resonator if you have the stock air box on the vehicle. This will direct all air suction to the fender well and that will be no good, especially if you don't have a skid plate or fender liner. I would only remove the intake resonator if you have a conical filter installed that can pull air from other sources besides the fender well. Some people have used a flexible pipe to set up "ram" air", directing the air from the plastic louvers next to the fog lights up into the air filter compartment. -
Re-Filling The Transfercase...without Making A Huge Mess?
PwninOBrien replied to kcpath's topic in The Garage
Yeah, I just picked up a pump (the plunger type with the clear hose) from Advance Auto and it did the job perfectly. It does take some time going back and forth filling up the pump and then pumping it into the transfer. -
I don't see how the mechanic could foreshadow the death of your engine just from a simple ticking noise. Somebody please tell me if I'm crazy or if I'm missing something here.
