Bassnurfaz
Everything posted by Bassnurfaz
  1. XPLORx4, again, thank you for ALL of your help! In regards to the noise, it only makes the noise when I go over bumps in the road, etc. It does not make any noise other wise. Also, there seems to be a lot of play in the front end. When I'm backing out of a parking spot and turn the steering wheel, it makes a single "clunck" noise that I can feel thru the steering wheel. It's not a continuous noise, only when I go over a bump at slow speeds, and turn the steering wheel at a stand still. PLEASE HELP!!! I don't want my wheel to fall off one day!!!
  2. Thank you both very much for your help, and thank you XPLORx4 for the pictures! Where do you get diagrams like the one above? They are very helpful :bow: ! So would you recommend just buying new bearings and seal having them repacked, or replacing the HUB, bearings and seal? Will that get rid of the play and some of the noise in the front end, when I go over bumps? Thanks again!
  3. I have a 1998 Pathfinder, and my local mechanic told me I need new inner and outer bearings. Apparently this uses a special press machine. Am I better off buying an entire new hub, or what's the best way to fix this problem? I used to have BFG Mudders on the truck, and I think they messed up the bearings. PLEASE HELP! I NEED IT BAD! Where can I find a Hub or an inexpensive solution? By the way, here's a link to my pathfinder. http://www.sounddomain.com/ride/226000 THANKS IN ADVANCE!!!
