For the past few months, my alt. and my a/t temp light have been glowing on my '88. Voltage checks reveal below 12 volts @ idle.....alt. r/r time I guess! Local parts houses get around $100 or so exchange for these remans. So I decided to get a chev v-8 alt. and throw it on instead (pt#7126). This is a real common one that puts out around 75+ amps, so I figured that was enough. I've got power everything, stereo, what not, so I didn't want something weak. I owned a '94 Altima that I did this on sucessfully, but the pathfinder is almost like a factory replacement! Now, the install: no new brackets, I believe you have to swap out one bolt( it's been a little while since I did this, mind you). You must rotate the alt, i.e; remove the 4 alt case bolts and turn the alt to the next set of holes. DO NOT forget to hold the brushes up when rotating the case. Anyway, bat term goes to bat term,ground to the case,of course. And there are 2 terminals on the chev alt marked 1 and 2 . The Nissan alt harness also uses two connectors. I wish I took notes on this one, everybody, as to which wire goes where. But I remember it wasn't hard to figure out (do a delco remy alt terminal i.d. search) that's what I did. No need to swap out the pulley or fan or nothin! I got this alt on sale with a lifetime warranty for $17. And seriously, it took just a little over an hour to do.
