Flexing01LE
    2001 Pathfinder LE 4x4 Home made F&R swaybar disconnects Home made E-brake rear traction control to suppliment LSD Home made aluminum skidplate 255/70R16 Goodyear RT/S rubber coming: Home made Siderz
    Skilled/Experienced Mechanic
Flexing01LE's Achievements
  1. How do you drive a '98 in the '80s? I drove a '83 Subaru back then. Oh, do you mean miles per hour? The MPH is a different rating. There will be a letter after the load index (your case was 114): M 81 mph 130 km/h N 87 mph 140km/h Temporary Spare Tires P 93 mph 150 km/h Q 99 mph 160 km/h Studless & Studdable Winter Tires R 106 mph 170 km/h H.D. Light Truck Tires S 112 mph 180 km/h Family Sedans & Vans T 118 mph 190 km/h Family Sedans & Vans U 124 mph 200 km/h H 130 mph 210 km/h Sport Sedans & Coupes V 149 mph 240 km/h Sport Sedans, Coupes & Sports Cars I would presume it would be an S or T, but I have seen some H in the SUV tires. Anything with a P or better is suitable for the highway.
  2. TR didn't have the extended load rating chart, but I was able to calculate it Load index lbs kgs 111 2403 1090 112 2469 1120 113 2535 1150 114 2602 1180 115 2668 1210 116 2734 1240 117 2800 1270 118 2866 1300 so you are looking at 2602 lbs per tire at about 35 mph. Sitting still, or rotating slowly would be significantly more (which is where you would care, right?). The LT tires are like 3415. You are comparing it to a Comercial rated tire. C = If a Euro-metric sized tire ends with a "C," it signifies the tire is a "Commercial" tire intended to be used on vans or delivery trucks that are capable of carrying heavy loads. In addition to being branded with the "C" in their size, these tires are also branded with their appropriate Service Description and "Load Range" (Load Range B, Load Range C or Load Range D). I didn't see what the specific load range was on your tire onward... LT = If a tire size begins with "LT," it signifies the tire is a "Light Truck-metric" size that was designed to be used on vehicles that are capable of carrying heavy cargo or towing large trailers. This includes medium and heavy-duty (typically 3/4- and 1-ton load capacity) pickup trucks, sport utility vehicles and full-size vans. Tires branded with the "LT" designation are the "little brothers" of 18-wheel tractor-trailer tires and are designed to provide substantial reserve capacity to accept the additional stresses of carrying heavy cargo. So I would assume that the LT is similar to C. With a 4200 lb truck, and 400 more in stuff you only have 4600 lbs. That means you could support the entire weight of the vehicle on two 114 tires at 35mph (5204lbs to be exact). Do you really think you need the C rating? I don't know what you intend on doing with your Pathy so I presented as much info as I could. Flexing '01 LE
