Git_R_Done
Everything posted by Git_R_Done
  1. Has anyone used the AC CV axles I saw them on there web site there only $97 each the cheapest I found them at a auto parts store is $99 plus a $75 core charge. I was wanting to know If they are better then the OEM ones you get at your local auto parts store Thanks Bobby
  2. Well I got my hitch oneday before I thought I was going to get it. Got got it in in about 45 minutes it was easy has hell. The only this left for me to do it the tranny cooler which should be easy. Thanks Slick for the info on installing the hitch and wiring and thanks to everyone elses input
  3. My hitch should be here Wednesday so I'll try putting it in when I get it. About a tranny cooler is there such thing of having to BIG of one? I found one thats 8" high x 17" long x1 1/2 " wide and is a 16 row cooler most of the the ones I've seen are 4-8 rows
  4. I'm just hoping the hitch install in just as easy. Slick, are you saying that there should only be 1 hole on each side? Because I have 3 hole on each side
  5. Slick, Thanks for the link to the write up on installing the harness that was the easiest install ever it only took me 10mins to do
  6. I'm planning on buying a fold up camper trailer and they have brakes. The trailer only weighs 1,400lb, but the dealer says I need the hook ups for trailer brakes and won't let me off the lot without. I was wondering how hard it would be to install on the truck myself.
  7. Trust me I'm planning on it. Has for wiring up for trailer brakes does anyone know how to do that so when I brake my trailer brakes engage, cause I was told I need a brake control box in my truck just want to know how to wire that up to. Thanks for wiring info that write up you did was awsome and makes it very easy
  8. I have a 95 pathfinder SE. What is the towing capacity for the truck? I lost the manuel so I can't look it up that way. Couple other questions the holes it the frame for me to bolt up the hitch are they threaded? if so, what are the thread size? and how hard is it to wire for trailer lights and brakes. Thanks Bobby
  9. I have a 95 pathfinder SE Just the other day my dash lights didn't come on but my head lights came on just fine I turned off my lights then turned them back on and everything was working fine but now I have no dash light or tail lights my clock light works but nothing else I checked all the fuses that had to do with the lighting system but they were all fine so I was wondering if anyone could help find the problem I can't drive at night now cause none of my tail lights work my brake lights and turn signals work Thanks Bobby
  10. I've used the search feature a 1000 times and haven't found what I was looking for so Im going to ask. I have a 95 Pathfinder SE with stock 15s I wanna put aftermarket 15x8s on it what is the bolt pattern and backspacing on the stock rims I want to give my truck that wider look without putting to much stress on the ball joints any help would be nice if you need anymore info on my truck let me know
  11. Where can I find the MAF adapters at and what is the part number I needed I orderes one off of ebay but it was the wrong one.
  12. I have the same cobra that in the 1st picture its the 25 ltd when I get everthing in the mail I'll try to see if I can get it to fit. How you guys mount your antenna I wanna mount mine to the rear tire carrier but don't know what bracket to use? Bobby
  13. Im Installing a CB radio in my 95 Pathy and wanted to know for those of you who have one where you mounted it I was thinking about putting it under the stereo deck since I have an aftermarket deck I have room there but don't know a way to mount it there thanks Bobby
  14. I wanna run a flowmaster muffler what series would be best to run I was told to run the 50 series SUV model I can get the 50 series for 20$ cheaper the then 50 SUV model what would happen if I ran a 40 series muffler all in all I want something that will sound good Bobby
