KP3S
Everything posted by KP3S
  1. I will check it out in the morning, thanks for the infomation. :coffee!:
  2. Still can't find the relay for the rear windshield wiper. I find out today that if I remove the fuse for the rear wiper the front windshield washer pump don't work, LOL. I disconnected the rear wiper at the tail gate.
  3. I tried that. I think either the switch is bad or the relay is bad. I just need to know where the relay is located, I know is not on the engine compartment, I checked all the relays there.
  4. Any1 one had this problem? 1992 XE Auto tranny that the rear wiper motor don't want to shut off, I was looking for the relay but can't find it or maybe is the rocker switch if any1 has one laying around and don't need it I will buy it. Also looking for the E-AT rocker switch. Thanks for reading.
  5. TO ALL THE FATHERS IN NPORA I WISH THEM A HAPPY FATHER'S DAY '09!
  6. Look at the size of the wires of the dome light and compare them to the wires of the 2 KC's. I myself would go straight to the battery since there might be a chance to overload the wire and cause wire harness fire. My 2 cents.
  7. I don't know if this is the correct section to post this. Doing a search I found this Nissan Pathfinder 1994 to 2004 Service Manuals free to download. Download password is: pdftown.com DOWNLOAD MANUALS HERE
  8. Good buy. Good luck with the install. Remember 16-17' of coax cable from the radio to the antenna, don't coil the execess cable but try to keep is as straight as possible because when you coil the cable it works like a signal attenuator, the signal will degrade.
  9. Wilson is a good antenna but a bit too expensive. But is a good choice.
  10. Mags tend to rust and they dont make an adecuate ground. If you hit a low tree branch it can be knock down. If you want to install a good antenna use a steel whip or fiberglass whip with a ball mount and a heavy duty spring, if the antenna is a steel whip take a tenis ball and make two holes and run the whip thru the ball to keep the antenna from grounding while traveling and touching the vehicle.
  11. You can increase the range of a CB by installing a 107" steel whip or a fiber glass whip with a ball mount that you can get at a good price at a big truck stop. American CB radios are not legal in Australia. Due to specs. In Australia they need a license to operate in the 11 meter CB band. In USA there is no license requirement. A good CB installation will be achived with a long antenna, a good ground system, grounding the antenna base and CB radio to the vehicle chassis will improve reception and transmission. If you experiencing ingnition noise in the RX/TX change the spark plugs and spark plug wires or reposition the CB radio/antenna will help most of the times or you can get a filter that oues on the red/black power wires directly from the battery. For greater range get a CB radio with AM/SSB, SSB (single side band) has an output of rf signal of 12W max and AM only 5W. If any1 wants more information I will help you, I am a license amateur radio operator since 1991. Good luck and have fun.
  12. Ok, thanks for the reply, now I need to get that switch that is not working on my Pathy.
  13. My '92 XE Pathy has this rocker switch bad, what this switch do?
  14. You could also go to Auto Zone or any big auto parts store and they can reset the ECU for you FREE of charge. I did when I had a Ford Taurus that needed a new gas cap, I bought the cap at Auto Zone and ask them to clear the ECU for me at the same time, they have a OBD II there to help customers find the right part for your vehicle.
