Nay-Sayer
Everything posted by Nay-Sayer
Bump
The Quest alternator works on the VQ35 engine?
Any recommendations on where I should get a replacement alternator? Was looking at what Rock Auto offers but wanted to get some input from here first. Thanks.
If I go the JY route, what about the wiring harness?
I'm in the process of buying an '02 QX4 which does not have a tow package installed. I was wondering if you guys could tell me the preferred method for adding one to this vehicle. Thanks
Nice looking truck. What size wheels and tires? Thanks.
Biggest tires I can fit under a R50 with 2" or 3" lift?
Nay-Sayer replied to Nay-Sayer's topic in 96-2004 R50 Pathfinders
What needs to be trimmed? -
2001 Pathfinder with 210k on the clock. I'm getting the P0505 engine code. Truck will start but will not idle. How do I diagnose and fix this issue? Thanks, Theo
Ok, as it turns out, the blower motor is bad. I pulled it out and it has two part numbers on it. 3H770 and 610100. A Google search on both of those numbers doesn't turn up anything definitive. I'm trying to figure out which part is the correct replacement part. Anyone have an idea? Thanks.
Do I need to remove the blower motor in order to do this?
I have a 2001 Pathy that has manual cloth seats. I just found a 2001 Pathy that's being parted out which has leather power seats. I'd like to swap out my manual cloth seats for these leather powered seats. Is this feasible? If so, what's all involved in doing this swap? Thanks
Replaced the resistor and checked the fuses but the blower is still not working. Any ideas? Thanks.
Ok, I had a look at Rock Auto's selection of oli coolers for my vehicle and they offer three; one light duty, one medium duty and one heavy duty. Do you have any idea of which one most closely matches the stock oil cooler? Thanks.
Looking to replace the oil cooler on my 2001 Pathy. Can anyone recommend a good source for this part? Thanks.
Changed the oil, cancelled the codes, drove 25 miles and so far the check engine light hasn't come back on. Can anyone recommend a good source for an oil cooler? Thanks.
Not yet. I'm going to have the oil changed to see if that makes the codes go away...
Bump.
Can a leaking oil cooler cause the engine to throw codes? The Check Engine Light just came on, codes P1110 and P1135.
It drips on the passenger side near the front wheel...
I have a 2001 Pathfinder with 211K. I bought it @ about 207k miles and the previous owner explained that it has an oil leak. Looks like it might leak somewhere around a quart or so every 1000 miles. Does anyone know what are common causes for oil leaks on these vehicles? Thanks.
Yes, my truck has the manual controls...
I have a 2001 Pathfinder with 210k miles on the clock. Recently the heater/AC blower motor died. Before the blower motor died, I was having issues with the on/off/speed switch for the blower motor. The switch would never select the correct blower speed. Now, the blower motor wont come on at all. I checked what appeared to be the correct fuses and they were both ok. Any help would be greatly appreciated. Thanks.
I changed the vaccum cut valve bypass valve about a week ago but my truck is still popping code P1491. What else can be done to correct this? Thanks.
Yes, the oil was changed 4 days ago. It was a quart low.
