lakeone
    Gray standard (stick) 4WD 1995 SE pathy . 178,000 miles
    Rarely Go Off-Road
lakeone's Achievements
  1. What is the cheapest why to fix my broken Odometer, Is there any do it youself procedure for that. THANX
  2. yes you are right my speedometre doesn't register more miles it's stuck on 177000miles
  3. Thanx guys, i guess i didn't put this right. it stopped on 177000 i meant to write that the dial went back down not the numbers i still have 177000 on the car
  4. I was on the turnpike and my Speedometer suddenly jumped back to 0, which then triggered the check engine light. it doesn't register more miles my car is a Nissan Pathfinder 1995 SE with 177000mile before the incident . I will like extre comment and advice too e.g cost of fixing
  5. Thanx for you response but i already checked the fuse not luck. And what is the ecu code? The regulator is for sale it's for the right back seat window
  6. I was on the turnpike and my speedometer dial suddenly went back down, which then triggered the check engine light. The speedometer doesn't count anymore i was told it could be the sensor Bcos 95's dont use cable anymore it cost $85 to get a diagnostic test my car is a Nissan Pathfinder 1995 SE with 177000mile before the incident . I will like to know if there is any do it youself solution to my problem. general comment are welcome like cost of fixing etc.
