Freeway
Everything posted by Freeway
	Hi, All!! My choice is - Nissan TD27T engine ( mechanical HPP, no belts-chains! - only mechancal) - Nissan Atlas 4wd Transmision+ Transfer gear - Toyotas FJ75 axles /w difflocks Now 1 project is finished. see attached pic file.
	Hi!! I've done Ecu diag on my Z24i engine. It's ok - code 55, but black smog from exhaust tell me that air/fuel mixture isn't ok ( end my Terrani eat too much fuel, sometimes idle drops too low ~ 400rpm). I know, that in normal mode ECU work in Mode I. Right, or not?? And my RED indicator is always ON. What is means?? :confused: Please help, I need for your suggestions. Thanks! Igor aka Freeway
	Thank you!!
	Hi, All! Please remind me the part number for Superlift UCA's. I'd like to buy it but I don't know p/n. Nobody wants to sell it from "stock of useful things" in garage or after upgrade your pathy? Good luck! Igor aka Freeway
	Hi,All! I've positive reaction after using Allied Nippon pads, Allied-Nippon site. This company is a part of Hitachi group, they primary products are bike brake pads (like ex. , AN is supplier for Sizuki and Kawasaki), but now they're manufacture cars barake pads too. Regards, Igor
	Hi! I'm not sure, but if you'll drive empty car this spring can live longer than any others. I saw the hint about Grand Cherokee V8 front springs, and after the little cutting this spring can fit ok. Do you hear about it? Igor
				Does anyone out there have a 4 cyl.?
Freeway replied to 87pathfinder4banger's topic in Z24 Engine Discussion
Thank you! About Terrano-Pathfinder difference The primary difference between Terrano and Pathfinder - transmission. All Pathfinders in our club are cars with auto transmission not like Terrano's with manual. Also termostat and visco for fan are tuned for the cold region. And there are many cars from Europe without condition. Igor -
	Hi, Andrey, I don't hear about BOGE springs. Can you tell me Boge part code? 10$ is really cheap price. I've asked for lifted sprigs on one St.Petersburg metal plant and they declare price $50 per piece. Niva spring is good for empty drives, but it lose height under any weight load (about 100 kg of cargo). Regards, Igor
Hi, again! I've got all infos from official Nissan program - FAST. It's very useful program with a lot pic's and infos. - like this steering page. All infos are avaliable on my site Terrano club , but on russian language only. I'ven't free time to re-design site interface and add english section. Sorry... But all filenames are english and you can surf my site for pictures. Regards, Igor -
	Hi, Kolobok7! You're not alone. I'm from Russia too. custom 2" lift (rear) Here is link for easiest way to lift of rear suspension. Regards, Igor
Hi, All! R&P set ratio for Europe models My Nissan Terrano with Z24i (which was build on Nissan plant in Spain) is equipped with diffs with 39/8=4.875 ratio for R&P set, and diffs carry marks RB48 and CA48 (for front and rear). So, if you see 48 in diff mark it means 4.875 ratio. Regards, Igor
