ca91pathy
Everything posted by ca91pathy
  1. Just a quick checklist. 5 sheet metal screws holding the metal shift boot ring, In ADDITION to the 2 at the carpet tabs. Total of 7 screws to remove. Plan on cutting your carpet. I had to to get my shifter boot off. Plan on cutting your fingers! Nissan has all but sharpened the metal ring. Also there are 2 snap rings to choose from. I saw the big one first so that is the one I pulled. As such I did not need a funnel. Amsoil sells 75W-90 GL-4 manual transmission/transaxle oil. Also, it is full synthetic and about the same price as the Redline. Might actually be easier to get as they have distrubutors all over the states. Took me about 2 hours with a warm trans.
  2. I pulled power for mine off the coil. It is only a trigger and the amperage comes from the battery
  3. When I first got my 91, the battery was not secured by the previous owner.as a result the 3 fuseable links at the + battery terminal were damaged and my headlights would go out frequently. Took about 1 week to figure out. I thought it was the headlight switch but replacing that didn't fix the problem.
  4. Hi everyone, Is the pathfinder transmission vented? The reason I ask this is because in boats I have always filled the lower unit from the DRAIN plug with a fitting and pump. I was wondering if this would work on my Pathfinder?
