dududuckling last won the day on November 2 2013
dududuckling had the most liked content!
About dududuckling
- Birthday 09/27/1986
2002 Nissan Pathfinder SE 2000 Nissan Pathfinder SE (2"AC/33's, 6"SFD/35's) - RIP
Screwdriver Mechanic
30-35
Rarely Go Off-Road
SE Offroad
2002
Contact Methods
MSN
andrew_27986@hotmail.com
Website URL
http://www.facebook.com/dududuckling?ref=profile
Gender
Canada
7,091 profile views
dududuckling's Achievements
NPORA Fulltime Resident (4/5)
16
ARB Sahara Winch bumper PN: 3938020
dududuckling replied to aussie4wheeler's topic in 96-2004 R50 Pathfinders
I had this mounted on a 2000 Pathfinder, and then brought it over to the 2002 -
In your opinion, is it worth the extra expense to go to 4.63 on a 3.5L? Currently have the stock 4.3, I believe. Will be doing lift to run 32's/33's. Thanks.
Yeah
Yeah, the temperature gauge does not move until you're about 175 F and stays where its at, halfway point, until 220 F. A lot can happen in the meantime. Pass 220 F, it will shoot up to just before max. The $50 ultra-gauge has saved me on two occasions now.
Replaced the radiator cap and that was it! Took it for a drive on the highway, mountain roads, and the temp was between 185 and 200F. Thanks all!
This morning I discovered that the coolant in the coolant reservoir was 3" from overflowing, way past the max limit and the radiator is empty. I think that could be the reason why. I am gonna get that checked out this weekend. I will be buying premix coolant for the meantime.
I see. My temp needle stays at 40-50% on normal driving 75-80 mph at 3000-3250 rpm (5-speed). The ultra-gauge reading goes between 195 and 215 F. It jumps from 199 to 203 to 206 to 210 and maybe back to 203, etc. At once instant, when doing 80 mph uphill with lights and stereo/amp/sub turned on, the temperature went up to 230F and that was when the needle went to 60-70%. As soon as I turned them off, the temperature came back down to 205-210F and so was the temp gauge needle. I am thinking a weak alternator or possible replace the fan clutch first (I know it is going bad and I thought I can get a few more months out of it).
The temp needle operates normally, and stays halfway or slightly below halfway under normal driving condition.
Guys, what is the normal engine operating temperature on the 3.5L (2001-2004 Pathfinder)? When pushed hard, i.e going 80 mph uphills, the engine temp needle stays the same whereas the ultra-gauge, plugged in to OBD 2, shows 220F. On norma driving, it varies between 200-210F. On the old pathfinder with 3.3L, it was only between 190 and 210F, maybe 215F on a super hot day and today was cold and chilly. Thanks.
Hi, I have just purchased a 2002 Pathfinder SE, 5-speed, 3.5L. Two codes came up today as I was doing 80 mph uphill: P0011 and P0022. I have read the forums about possible causes, such as camshaft position sensors, timing solenoid???, low oil level, dirty oil. Oil level is good and it is clean. What other possible causes it might be? The mechanic suggests resetting the CEL and see if it comes back on. But I don't think that really solves the problem. Also, does anyone do the powervalve screws fix? I have called a few Nissan dealers in Los Angeles and they have not heard of powervalve screws failures. Any thoughts? Thanks!
I replaced the oil pan because the drain plug broke, and the stick stuck because they didn't remove it prior to putting the new pan in.
Normally I put in 4 qt with new filter and when its time for next oil change, I get around 2.75-3 qt in the jug. I figured the rest might just be soaked in the filter. Do you happen to know if removing the dipstick guide is a big job?
Hi guys, I had a local shop replaced the oil pan back in June and this is on a 3.3L V6 - 2000 Pathfinder. I found out that the oil dipstick is stuck because they did not remove it prior to installing the oil pan. The dipstick sticks 3" out of the guide and its stuck for good. The motor runs strong and has clocked in 5000 mi. since then. As I could not check the oil level, I added 0.5 Qt. at 2500 mi. Today, when I braked and made a left turn, the low engine oil pressure light came on for a brief second and went off. So I added another 0.5 Qt. I am going to get an oil change next week. When the pathfinder had a function dipstick, the oil level was always at full and so I am not sure if the truck is burning oil. Maybe it just evaporates? Is it possible to remove the dipstick guide, trim the stuck dipstick, put the new dipstick into the guide? I do not plan to keep the truck much longer and would prefer to avoid having to reinstall the oil pan. Thanks in advanced.
Nice find! Any idea how much the body shop would quote you to cut and weld the replacement pieces? Thanks
My ABS light is on, haven't pulled the code, i'm pretty sure my abs isn't working. Sometime when it rains or after carwash, the ABs light would go off for a while and come back on, haha... But no clunking noise until recent rainfal (it rains like twice a year here) Ill replace the druver side bushings and see if itll fix. Thanks for the note on the passenger side bushing. I always thought if it moves, I'll see shiny metal.
