Everything posted by rickyspath
Is that a CB antenna? Sent from my iPhone using Tapatalk
I need some help with my '02 pathfinder le. someone broke in and stole my stereo, when they ripped the dash out they ended up pulling the hazard switch out, so I have already replaced the the switch and cut the old wires out and soldiered a new plug. The problem is that every time I turn headlights the lights inside won't light up, I have no cluster, heater unit, shifter, light all the gauges work. I have checked all the fuses one at a time but nothing. I have no idea what to do. Sent from my iPhone using Tapatalk
First actual mod kinda hahaha 2in wheel spacer just the rear Sent from my SM-N900T using Tapatalk
That's sick af. Wheel Spacers ? Sent from my SM-N900T using Tapatalk
02 pathy skid plate
rickyspath replied to rickyspath's topic in Solid Axle Swaps, Hardcore Custom Fab
Great thanks Sent from my SM-N900T using Tapatalk -
Anyone know where to get a good ski plate for a 02 pathy. Or custom? Which one comes out better? Sent from my SM-N900T using Tapatalk
Anyone have any good tips. To when it comes to replacing the lower pan gasket on 02 pathfinder 4x4. And Do's and Don't. I would really appreciated it. Sent from my SM-N900T using Tapatalk
And my year finally begun. Sent from my SM-N900T using Tapatalk
Do you have wheel spacer in the front? Sent from my SM-N900T using Tapatalk
I changed the struts and shocks but not springs they seem fairly new. I found the old service manual and a ton of receipts the (mostly water damaged) but the springs are under 5yrs old Thanks for the help Sent from my SM-N900T using Tapatalk
Anyone knows where I can find the rear bumper for a '02 pathfinder painted. Doesn't have to be new. Sent from my SM-N900T using Tapatalk
Di you have any pics from the side with the 2in spacer? I've been wanting to install similar but not sure if it will be out too much. Sent from my SM-N900T using Tapatalk
When changing the front struts, should the springs be replaced as well? Sent from my SM-N900T using Tapatalk
Thank you. Are you the admin? Sent from my SM-N900T using Tapatalk
Hello Everyone, I know I'm still new the NPORA FORUM but I need some help lifting and spacers. Not looking to go that crazy on the lift maybe 1 to 2in . Any help would be appreciated. And Thanks in advance. Sent from my SM-N900T using Tapatalk
HELLO, NEWBIE TO THE PATHFINDER WORLD
