David4x4
    2004 Nissan Pathfinder or 4x4
    Rarely Go Off-Road
    Fresno
David4x4's Achievements
  1. I had a similar problem and it was the strut mounting bearing. I bought a cheap 1 and found out a week later it was broken already. Try that out and see if it the problem
  2. So my buddy gave me a free filter and I just noticed it doesnt have a place to put a hose in like the stock airbox that suppose to have it. Will it be ok for me to run it unplugged.
  3. I cant seem to find the torque spec for the lower and upper manifold bolt. Can someone please help me out. Thanks
  4. Does anyone know if the pnp switch has a gasket or can leak tranny fluid. Thank you
  5. I see so the valve cover and spark plug tube is serviceable but why did Nissan tell me it wasn't. I guess I'll buy the spark plug tube from autozone and see how it goes. Thx
  6. Hi I'm leaking oil a little on one of my spark plug tube and the dealership want about 300 for the passenger side valve cover. Since the spark plug tube is not serviceable. Does anyone know where anywhere sell aftermarket valve cover or any other car that has a valve cover that is similar that will fit. Thx
  7. I have a 04 pathfinder and just discover it started leaking by the pnp switch. I check the turbine sensor area and it seem dry. I also see a few hose but they seem dry also. Its only that turbine revolution wire. Question is does that sensor have a hose inside that wire cover dressing.im full on atf fluid also. Any help is greatly appreciated. [/ur
  8. I see so from the link you posted in here it look like it's possible but not recommended. I guess I just have to take it apart and see if I can put the cheap felpro in. Thanks a lot
  9. So I just bought a used 04 pathfinder and it has 137k mile on it. I did oil change and spark plug on it. Then realize one plug on the passenger side had a good amount of oil on it. Went to dealership to buy some spark plug tube and they said they don't sell the tube and I have to buy a new vavle cover. I think it's b.s but I can't really find anything online that say if the spark plug tube is bad I have to buy a new vavle cover. Can someone tell me if it true or not. Also Autozone they said they have the gasket and tube but the dealership said he guarantee it will not fit or stop the leak unless I buy the new valve cover. Thx guys
