SteeevO Posted June 28, 2006 Share Posted June 28, 2006 ok so everyhing is waiting for the welder to do his thing so i can finally have 4WD and the last thing for meto do is hook up the lil frigg'n light that comes on when in 4WD. today o have blown 2 fuses trying to use the wiring that looks like was installed as if it were a 4WD pathy from teh factory.. rar frustrated.. i need help from someone that has a 4WD. there is set of wires that runs from under the hood to all the switches on the tranny. how many wires are there? 4 or 6? and what colors are they and what colors go to what switch? if that info cant be found then i need to know how many volts those lil bulbs in the dash require so i can run my own wire to then w/o frying the crap out of them. however i am thinking that the wires that i need are already in the pathy becasue i took appart the dash and the wires are there for the bulb but i don't know where they go from there.. if i knew where they went, i would be hooking up the switches to those wires and not have blown 2 fuses and been frustrated over a frigg'n light bulb for 6 hours today... any help on this would be greatly appreciated -Steven Link to comment Share on other sites More sharing options...
cdhicks99 Posted June 28, 2006 Share Posted June 28, 2006 I can check tonight if no one else gets the answer. Link to comment Share on other sites More sharing options...
SteeevO Posted June 29, 2006 Author Share Posted June 29, 2006 i got it fugured out today thanks but thanks anyways Link to comment Share on other sites More sharing options...
