dash swap and lock ques
Maz
Is it possible to swap the dash froma 95 + path or truck into a 91 path? Will it boly right in and heater controls guages etc work?
Locks ... I have power locks when I lock it and close the door the locks pop back up is this normal? If I hold up the handle they stay locked
Thanks
Jamie
i think the dashes for all wd-21's (86-95) are pretty much the same. i believe some HVAC controls are slightly diff tho, so youll just have to check.
as far as teh locks situation..yes this is normal. you must hold the handle up in order for it to remain locked when you shut it
