New Engine + Transmission
aeternaldark
Well the problem is not what will fit, but what do you do about the sensors and computer. If you do not want to swap out your computer and the wiring harness then you are stuck with 1990 to 1995. Pre 1990 did not have a knock sensor so the computer will fault without it there. Of course you could add one. Post 1995 again the issue is the sensors. They are slightly different and produce different voltage for reading. You did not say which tranny you need, but if you are changing out both then I guess it doesn't matter.
