solid diff.
mudfinder
hey guys, what's going on? well, i'm planning on starting to SAS my Pathfinder. i'm 2wd, gotta find a tranny and t-case. anyway. i'm starting to gather all the parts. i want to get the calmini SAS kit. hopefully it'll come out by the time i finish collecting the parts. i need help from you guys. i wanted to put a dana in the front. i'm thinking of pulling one from the junkyard and rebuilding if i need to(most likely i'm gonna have to) what type vehcile can i pull a dana off of? jeep, chevy, ford? thanx
If you want to keep your wms-wms close to stock, a Jeep Grand Waggy is a common choice. Chevy will be full size and most likely passenger side drop (However, you are 2wd now, so you could go either side. What T-case are you going with?) Ford will be full size unless you find an EB and both will need converting to 6 lug. A high pinion Ford D44 is a very nice choice.
