PCV and connecting hose problems
JasonR
Hi all :)
So I have a Pathfinder 2005 (AU Plated) R50 model I believe ...
Having a huge problem trying to find the PCV hose that is connected directly to the PCV Valve ...
Its a firm U shape molded hose, and my question is ... can i use an alternative hose that may be flexible enough to get from "point a to point b"
Thanks in advance ... J
Absolutely, I think you should be able to use any hose, just as long as there aren't any kinks in it, you should be golden..
Sent from my LG-H700 using Tapatalk
On 5/9/2020 at 2:06 AM, JasonR said:
Hi all :)
I did
