Head Gasket Replacement/tips
So after some "mayo" on my oil cap and dip stick and chocolate milk oil I decided time to dig in and change the head gasket. I will go through my tips steps and anything involving it. Just know I'm not a full bird mechanic just hobbies so sorry if it's not all verbally correct. Here are my before/reference pictures.
Sent from my Pixel using Tapatalk
Tools you will need-
Full metric sockets deep and short
Full standard sockets deep and short
Extensions long and short
Tape(to mark stuff with)
Torque wrench
Screw drivers
Allen key sockets
Breaker bar
Pully puller(the two bolt one)
Time
Luck
Patience
I'll add any I missed
Parts you'll need-
gasket set(inclueds all the gaskets you will need)
New head bolts(13 per side)
Brake cleaner
Degreser (trust me)
I'll add as I go
Did you have to take your heads to the machine shop for milling?
Only of they are warped look on like and it will tell you how to check
Yeah I know. I was asking if you had to have yours milled.
I didn't no but I did have to get a broken rocker bolt removed
