onespiritbrain Posted March 26, 2017 Share Posted March 26, 2017 So I've looked at all the drawings for the SFD 4in strut spacer with camber compensation and I don't feel comfortable my ability to follow what info and drawings there are. I have searched extensively and haven't found a good detailed "how to" for the SFD strut spacers. Does anyone know of one that I might have just missed?? Does anyone fabricate them on this forum? Can you order just the SFD strut spacers from Krypton? Thank you Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
onespiritbrain Posted March 26, 2017 Author Share Posted March 26, 2017 *cough cough fleurys cough* Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
TowndawgR50 Posted March 26, 2017 Share Posted March 26, 2017 Take a protractor, set it to 8 degrees, mark a pipe, cut both sides parallel at 8 degrees to a length that will equal 4" after your plates are welded on (example- cut pipe to 3.5" if using 1/4" plate), copy the strut mount onto some plate and cut drill as needed and weld it all together making sure the orientation of the strut mount bolt pattern and the 8 degree slope matches your rig. Sounds harder than it really is. Grab a grinder and a welder and go for it. 1 Link to comment Share on other sites More sharing options...
fleurys Posted March 27, 2017 Share Posted March 27, 2017 *cough cough fleurys cough* Sent from my iPhone using Tapatalk LOL ! 1 Link to comment Share on other sites More sharing options...
