Problem installing manual locking hubs - Advice?
DanF.
new member/PF owner researching this hub issue.if flange on mm/warm hub is the same dia. as lip on rotor,wheel should seat down to rotor face unless interfere nce somewhere else inside wheel. going by the pics. ?
What wheels do you have? Post a picture if you can.
I'm confused what rotor issue you'd ever have. The lip on the inside of the SE wheels holds the center caps, and will prevent the MM hubs from poking through enough to allow the wheels to fit back on the hub.
IIRC, the SE wheels that I have are the only wheels that will have interference issues with the Mile Marker hubs. It's also been said (somewhere on this forum...) that Warn hubs will fit without modifying the SE wheels. I don't have the dimensions for the Warn hubs, so I can't speak to that.
Hope this helps.
