Valve Cover Gasket Leakage
Thanks in advance for your thoughts on this...
I have an 09 Pathfinder that has a valve cover gasket leak. It's very minor but it's still there after I replaced the gasket. It is leaking from the front, not the back as is common. There was a bit of silicone at the spot where the oil is leaking as well like someone had already articulated leakage there. Any help would be fantastic. Thanks!
