JayTheGent Posted April 15, 2016 Share Posted April 15, 2016 I recently replaced my distributor. After getting everything lined up, she fired right up. I drove to the store and when I came back out, she'd crank hard but not turn all the way over. I pulled the plugs, they weren't wet so I assumed I was getting spark. I pulled the fuel return and a large amount of gas sprayed out. When I got home, I adjusted the distributor again and she fired up (I didn't move a tooth, I just turned it a bit). Drove good for a couple of days, then the same thing happened again. I moved the distributor aND relieved the fuel pressure and got her to start. I busted out the timing light, I was between 5 to 10 degrees BTDC. I don't think that's enough to cause a no start... I just moved to 15 BTDC. Please let me know what you think! Link to comment Share on other sites More sharing options...
Cuong Nguyen Posted April 16, 2016 Share Posted April 16, 2016 Stock timing is 15* BTDC. Did you get a new distributor or a used? How many miles? Perhaps gas cap is not venting? Link to comment Share on other sites More sharing options...
