anzaman Posted January 23, 2015 Share Posted January 23, 2015 Should there be any "play" between the steering column transfer gear where it connects to the rack and pinion unit? If so, how much, and if not, is it the result of a bad gear in the unit? My steering is "sloppy". Link to comment Share on other sites More sharing options...
01Pathmaker Posted January 23, 2015 Share Posted January 23, 2015 You should check the rack bushings, it's fairly common for them to deteriorate and give you sloppy steering, much cheaper and easier than replacing the rack. Link to comment Share on other sites More sharing options...
