R50 Headlights.
GePa
Just two simple question. The headlight of the R50 gen 1 uses relays?
If they do use relays it's safe to use 100/80 bulbs? And i mean true 100/80 bulbs made by Trusted companies not
some chinese crapp.
The answer to your first question is yes, the R50 does use a headlight relay. There are 6 original oem part numbers but 4 of them are now superceded to the other 2. The only current part numbers are 25230-79917 AND 25230-79981. The best way to find out which one you need is to match up the number on your old relay.
