Aftermarket Catalytic's 1997 R50
Oleschool
I don't know if its an O2 sensor.I've been told that if an O2 sensor is bad the readings will be significantly different than the others.In this case it is pretty close.I've also read a post somewhere that said the cats were almost always faulty when this code came up.My cat on the pass side is cracked,which I believe to be a Nissan TSB.There is a band type clamp around it with some sealer on it.
Is the pass side Bank 1 or is it the drivers side?
  • 3 months later...
