gilman17 Posted January 1, 2014 Share Posted January 1, 2014 I was checking my o2 sensor after I was done the transmission won't shift out of 2nd gear and the torque converter doesn't lock up.It's driving me crazy I have checked fuses vacuum lines wire connections still nothing helped.Fluid is full.It worked fine until I messed with the o2 senser had the air cleaner off,checked all connections,wires vacuum lines.Can anyone help me?Ed Gillam phone is 208-258-1692,email gilman1747@gmail.com Thankes ED Link to comment Share on other sites More sharing options...
gilman17 Posted January 4, 2014 Author Share Posted January 4, 2014 I found the problem a mechanic told me to pull apart the wire connecters for the transmission and put them back together this solved the problem trans shifts fine it was just a loose connection,ED Link to comment Share on other sites More sharing options...
