Two quick questions...
Guest PeterB
Hello Everyone/Anyone,
Just wondering if someone can refresh my memory. I double checked the timing on my 94 and there are 4 timing marks on the flywheel. I cannot remember where 15 deg. is in relation to these 4 marks. Can't find my shop manual, sorry.
Also, just got the truck back from the shop and it idles too high. I checked for vacuum leaks but couldn't find any. It's idling between 1000 and 1500 RPM no matter what. I can't figure it out. New plugs, wires, cap, rotor, fuel injectors cleaned, pcv valve replaced etc. Any ideas would be very much appreciated. Oh, I ran the ECU diagnostic and it came up 5-5 i.e. nothing wrong. Prior to the tune up it idled perfectly steady at around 700 RPM
Thanks in advance!
Peter.
Edited by PeterB
