PrestonBurns Posted October 4, 2013 Share Posted October 4, 2013 My OBD is reading this, is this the sensor on the exhaust pipe before the cat on the passenger side? If so, how hard would it be to replace this at my local Advance with their rental tools? I say this because I'm down in my college town without my tools at home at my disposal. Thanks! Link to comment Share on other sites More sharing options...
Towncivilian Posted October 4, 2013 Share Posted October 4, 2013 Bank 1 is the side with cylinder 1, in our case passenger side. Sensor 1 is the upstream sensor. If you can wait until morning I'll provide a link to the direct-fit Bosch O2 sensor (Bosch is the original equipment manufacturer) from AAP along with a discount code, and which size O2 sensor socket you'll need. It should be very easy to replace an upstream sensor, there's much less wire to snake around. Link to comment Share on other sites More sharing options...
PrestonBurns Posted October 4, 2013 Author Share Posted October 4, 2013 Thank you! I look forward to it. Link to comment Share on other sites More sharing options...
Towncivilian Posted October 4, 2013 Share Posted October 4, 2013 I need the manufacturing date of your Pathfinder to determine which sensor is correct for your engine, which can be found on the driver door jamb sticker. Link to comment Share on other sites More sharing options...
PrestonBurns Posted October 4, 2013 Author Share Posted October 4, 2013 07/00 Link to comment Share on other sites More sharing options...
PrestonBurns Posted October 5, 2013 Author Share Posted October 5, 2013 I just ordered part 13531 from AAP. Correct me if that was incorrect. Link to comment Share on other sites More sharing options...
Towncivilian Posted October 5, 2013 Share Posted October 5, 2013 That is the correct part. Did you use any discount codes? Link to comment Share on other sites More sharing options...
PrestonBurns Posted October 5, 2013 Author Share Posted October 5, 2013 I didn't. It was at autozone as well. It was about $10 cheaper Link to comment Share on other sites More sharing options...
PrestonBurns Posted October 7, 2013 Author Share Posted October 7, 2013 Is the sensor on the passenger side on the top of the engine below the plastic covering? Link to comment Share on other sites More sharing options...
Towncivilian Posted October 8, 2013 Share Posted October 8, 2013 I don't know its exact location but it is on the passenger side. Removing the engine cover may help you find it. Its harness is connected to the passenger side too, there will be a red and a blue colored connector attached to a bracket if I recall correctly. Link to comment Share on other sites More sharing options...
PrestonBurns Posted October 8, 2013 Author Share Posted October 8, 2013 For some reason I thought that it was on the underside of the car; After comparing the wire lengths and connectors I determined it's on top of the engine. I also discovered that my roommate stole my ratchet and my 10mm socket, which is all I need for the job. Link to comment Share on other sites More sharing options...
PrestonBurns Posted October 8, 2013 Author Share Posted October 8, 2013 There's the replacement, if only I could figure out where in the hell it belongs. It's got about 5 inches of wiring, the 3 that I've found have long wiring. Link to comment Share on other sites More sharing options...
Towncivilian Posted October 8, 2013 Share Posted October 8, 2013 You see that bracket next to the A/C low pressure line (with the green cap), with the gray plug attached to a bracket on the side of the engine? The gray plug is the original sensor's harness. Trace it back to find the sensor. Link to comment Share on other sites More sharing options...
PrestonBurns Posted October 8, 2013 Author Share Posted October 8, 2013 I did that but the wire is far too short. Did I get the wrong part? Link to comment Share on other sites More sharing options...
PrestonBurns Posted October 8, 2013 Author Share Posted October 8, 2013 Also, what OBDII readers do y'all reccommend? Link to comment Share on other sites More sharing options...
Karmann Posted October 9, 2013 Share Posted October 9, 2013 I replaced my O2 sensor on Bank 2 with a Bosch unit a few months ago. It was underneath the car on the driver's side, basically between the body and the tranny, with several clips along the way to hold it in place. They're very fiddly- watch out. If I remember correctly, it plugs in toward the front of the engine. I bought a U-Scan OBDII reader, and thus far has been quite helpful- free Android/Iphone app which allows you to diagnose nearly anything. You can also buy a $29 expansion that has specific code decoding to your vehicle. Link to comment Share on other sites More sharing options...
Towncivilian Posted October 9, 2013 Share Posted October 9, 2013 I suggest this ODB2 reader and Torque Pro ($5) if you have an Android smartphone. Link to comment Share on other sites More sharing options...
PrestonBurns Posted October 10, 2013 Author Share Posted October 10, 2013 Can somebody direct me to the right o2 sensor? Link to comment Share on other sites More sharing options...
