tote Posted August 30, 2013 Share Posted August 30, 2013 Passenger head light low beem working intermitantly. checked easy stuf first i think. Is there a control module in this thing? Thanks. Link to comment Share on other sites More sharing options...
Towncivilian Posted August 30, 2013 Share Posted August 30, 2013 First swap the driver and passenger side bulb to see if the problem moves or stays at the same light. If it moves, the bulb is at fault. If not, there is something with the wiring going to that headlight. Link to comment Share on other sites More sharing options...
tote Posted August 30, 2013 Author Share Posted August 30, 2013 Istalled new bulb ,the high beem works and the low works some times.I have swaped out two new bulbs as they came as a set both act the same ,fures good and relies good to , swaping from side to side. Thanks Link to comment Share on other sites More sharing options...
Towncivilian Posted August 30, 2013 Share Posted August 30, 2013 See the relevant trouble diagnoses on page EL-61 of the factory service manual. Link to comment Share on other sites More sharing options...
tote Posted August 30, 2013 Author Share Posted August 30, 2013 Thank You Link to comment Share on other sites More sharing options...
keelhaul Posted August 30, 2013 Share Posted August 30, 2013 daytime running light circuit board. grey/beige box behind battery on fender. replace or bypass, some have had luck re-soldering connections on circuit board inside box Link to comment Share on other sites More sharing options...
tote Posted September 1, 2013 Author Share Posted September 1, 2013 Thank you The lubeman for the manual it will come in handy. I changed the day light control module that cost me $351.00 (crap) any way that fixed it. Thanks for your guys help it was very fast and very helpful,.Ill keep this thing for a will yet ; Tote Link to comment Share on other sites More sharing options...
