cv axle inner boot repair kit
rig002
Ok i did install all new cv.axles on 2001 pathy le. And after a month i found the passenger on Inner boot split in half ( inner is the end that connects with 6 bolts to the front gear box / axle). I dont wanna go thrugh all that hassle for now, so im looking for a quick fix / split boot kit, but all that i found is for the outer boot.
Anyboby knows where i can find this inner boot kit? Or if the outer boot will fit the same? Please help.
I do have manual lockers so i dont use the axles for now, but this quick repair is to eliminate more corrosion or damge into the axle joints.
Thanks
Inner boot is not supposed to be a user-serviceable item. If that fails, you're supposed to replace the whole axle. It's a different size than the outer boot, so that won't work. I have a spare axle that I've been trying to find those ring clamps for the inner boot, and I can't even find those.
