2001 limited slip differential oil
vanuatoo
A friend of mine has 2001 pathy and he wants to change the rear diff fluid.
Owners Manual says to request recommended oil from the Dealer.
Which oil should be used for rear limited slip differential gear oil change?
I would use Mobil 1 LS 75W-90. You'll need 3 quarts. Be aware that the fill and drain plugs are 13mm, a bit larger than 1/2" (12.7mm). Nonetheless, try a 1/2" drive breaker bar with a short extension on it to remove the fill and drain plugs. Always remove the fill plug first! The torque spec for both plugs is 43 - 87 ft-lbs.
