DTC P0325
TacitBlue
I've had some EVAP code issues, but as of now, the check engine light is off (knock on wood). My question is, in the shop manual, it says a knock sensor fault doesn't trigger the check engine light, but there is a DTC for the check knock sensor (P0325), every time I got an EVAP code, the knock sensor code was always there also (P0325). When I do work on the car to fix the EVAP system, the knock sensor code never comes on by itself. The time I had the car at the dealer for the knock sensor and EVAP code, they only got the EVAP code. What's going on here? I don't hear or feel any engine knocking, what's the deal with the knock sensor not setting off the check engine light, but there is a DTC code for it???
I don't have a DTC for knock sensor on now. I can't clear individual codes, only all or none. The DTC for the knock sensor would only come on with varying EVAP codes. I never did any work to address the knock sensor code, but I did do work to address the EVAP codes and sometimes the check engine light would stay off for a couple hundred miles. I'm wondering why the check engine light isn't coming for just the knock sensor code after a drive cycle. I use 87 octane fuel.
