little lift question
I haven't seen a spacer specific to the WD21. I recently spent some time at the junk yard looking around at other vehicles trying to find something with more aftermarket support. I found that the front coils in a 97 Dodge 1500 2WD are very similar to the factory WD21 rear coils, or in my case the ARB OME 3/4" med duty coils. The Dodge coils are obviously shorter, but the Inside diameter is identical. The Dodge coils are thicker so the Outside Diameter is about 1/8" larger, however the dodge coil/isolator fit perfectly into the coil bucket on my WD21. I actually just ordered a 1 1/2" coil spacer for a 2WD 94-11 Dodge 1500-3500 from Daystar Part Number KC9013BK, and will certainly post here how it works with the Nissan coils. This is the "budget boost" spacer and cost me $45 CDN. They also make identical spacers in 1" and 2 1/2". Keep in mind that a spacer designed for 1 1/2" lift on the front IFS of the dodge isn't going to be a 1 1/2" spacer, the actual thickness of the spacer is going to be less as there is suspension geometry in the Dodge that Daystar has incorporated into the design.
You could also order 1 1/2" lift springs from www.4x4parts.com, Install OME springs for 3/4" or install Jeep Cherokee coils for 3" lift. There's a ton of other threads on here that cover this. The front you can adjust / re-index your torsion bars. Again there's a ton of threads on here for this you'll just have to look around.
Hope this helps
