pathytic Posted November 8, 2011 Share Posted November 8, 2011 i installed OME medium front springs over gr2 struts 98 path 2wd installed raybestos camber kit, but i still got positive camber... what should i do? Link to comment Share on other sites More sharing options...
devonianwalk Posted November 8, 2011 Share Posted November 8, 2011 Is the camber kit (bolts I assume?) mounted correctly? They can be used for positive or negative camber +\- 4 degrees IIRC. Link to comment Share on other sites More sharing options...
pathytic Posted November 9, 2011 Author Share Posted November 9, 2011 Is the camber kit (bolts I assume?) mounted correctly? They can be used for positive or negative camber +\- 4 degrees IIRC. raybestos 616-1036, it's just +/- 1 3/4 degrees... do you know what brand can give me +/- 4 degrees? Link to comment Share on other sites More sharing options...
Igetstabby Posted November 9, 2011 Share Posted November 9, 2011 The AC camber bolts are supposed to be good for 2 degrees... A little expensive though. Not sure if any other readily available brands give this much adjustment. https://www.4x4parts.com/nissan/camber-alignment-kit-p-2809.html Link to comment Share on other sites More sharing options...
devonianwalk Posted November 9, 2011 Share Posted November 9, 2011 The AC camber bolts are supposed to be good for 2 degrees... A little expensive though. Not sure if any other readily available brands give this much adjustment. https://www.4x4parts.com/nissan/camber-alignment-kit-p-2809.html I stand corrected. +/- 2 degrees. These are the bolts that I am using. Thanks Stabby! Link to comment Share on other sites More sharing options...
