Turbocharged Pathfinder carving a dune
slick250
I guess not engaging the front drive axle does keep those CV shafts from breaking if you go hard on it. It does pretty well in the sand for being only RWD. You have the LSD rear axle right? That should help you to keep moving on low traction surfaces like snow and sand.
