Trogdor636 Posted June 26, 2011 Share Posted June 26, 2011 What size is it? It looks doable with a deep drive socket, or am I incorrect? Easier to take off the tire and go at it that way? I believe mine is the cause of my slow oil leak, so I'd like to change it out. Thanks! Link to comment Share on other sites More sharing options...
Cuong Nguyen Posted June 26, 2011 Share Posted June 26, 2011 I don't know what size it is but you can use a deep socket or a crescent wrench. Removing the tire will give you more Room to work with. I have a body lift so it makes it easier to access. The valve cover gaskets have a tendency to leak over time. The typical fix is to just tighten the valve cover screws. thought I throw that in for some FYI. Link to comment Share on other sites More sharing options...
Trogdor636 Posted June 26, 2011 Author Share Posted June 26, 2011 I don't know what size it is but you can use a deep socket or a crescent wrench. Removing the tire will give you more Room to work with. I have a body lift so it makes it easier to access. The valve cover gaskets have a tendency to leak over time. The typical fix is to just tighten the valve cover screws. thought I throw that in for some FYI. Yea, I have tightend those. Its nothing major, it just seems to be coming from there, like through the unit itself. I had a 25mm on it and it was slightly too big, so off to Sears in the morning to buy a new socket. Thanks for the info. Link to comment Share on other sites More sharing options...
