rgallant Posted June 13, 2011 Share Posted June 13, 2011 Hi all, Just had my front end re done OME MD springs, KYB struts, NAPA bearing and top end bits. Had a squeak sort of similar to a hard turn at a stop where the tires rub the pavement. Appeared after about 90 km when turning the wheel at slow speeds, under 15 Kmh comes from the dvr side strut top. Hit it with some silcone and a drive down a nice wash boarded road squeak went away. Do I need to worry or is this just new bits settling in ? Link to comment Share on other sites More sharing options...
muddfildvaynes Posted June 13, 2011 Share Posted June 13, 2011 Sounds like upper strut mount also known by some to be the "strut bearings" you want to get that taken care of when you can as there have been some members on here who have had catastrophic results with bad strut bearings. Link to comment Share on other sites More sharing options...
rgallant Posted June 13, 2011 Author Share Posted June 13, 2011 Hmm.. Weird I had the upper mounts and bearing replaced at the same time for that very reason, I did not want to have to worry about it. Ah well back to the shop to have them take a look. Link to comment Share on other sites More sharing options...
muddfildvaynes Posted June 14, 2011 Share Posted June 14, 2011 did you get them with the coils from the same company? Get the ones directly from the dealer, they are alot stronger; I had mine go out on me in 2 weeks after I did it all. Link to comment Share on other sites More sharing options...
rgallant Posted June 17, 2011 Author Share Posted June 17, 2011 Just an update looks like it was small binding issue nothing too serious. My local mech took a look, everything seems fine. If anything goes south I will pass it along, but just to make sure I put the front end in the air and manually moved the tires, there was no obvious binding. Springs are OME Struts are KYB GR2 Bearing Kit from Napa everything except the stud section. Link to comment Share on other sites More sharing options...
