freyspath Posted February 28, 2011 Share Posted February 28, 2011 I was just doing my oil filer and fluid change when I noticed a small leak! The leak seems to have been here for some time, much of the dripped areas are full of grime. It looks to be coming from the left of the oil filter area. (left being your looking at the car from the front. otherwise better said its on the passenger side.) Maybe its from the Oil pump? I did notice it was leaking onto the inner CV joint and the only thing above are two hoses and a pump looking thing... Thanks guys Link to comment Share on other sites More sharing options...
fleurys Posted February 28, 2011 Share Posted February 28, 2011 search the forum for oil cooler leak... you;ll see that is not a big or costly job. Link to comment Share on other sites More sharing options...
Towncivilian Posted February 28, 2011 Share Posted February 28, 2011 Does the part that's leaking look like this: If so, your oil cooler is leaking. It's probably an O-ring that's busted. You should replace both while you're at it, they're cheap. Read this thread over at NICOclub for more information. Link to comment Share on other sites More sharing options...
freyspath Posted February 28, 2011 Author Share Posted February 28, 2011 ^^^^ YES! It is that thing! THANKS SO MUCH Link to comment Share on other sites More sharing options...
